07GTS
- Sep 8, 2013
- 5,053
- 6,835
- 113
- Location
- Australia
- VEGTS BUILT BLOWN E85
ethanol tables are triggered by frequency which then relates to the corresponding tables, also needs error codes/tests enabled to work so if it wasnt setup right it would cause codes and default situations, would be way easier to use the IAT sensor if its downstream from the shot to cool it or trigger a resistance value when nos is on which takes the place of existing IAT value then use the iat spark retard table to do what ever u want with the timing in that set temp row
