RHF DOOR DENT advise.
dmp8810
Gold Coast QLD
07 VE SV6
07 VE SV6
not sure whats done it, blunt object i suspect.
RHF door theres a dent, the largest part is at the top as indicated by the diagram.
I tried to push it out, its worked slightly. But i need more pressure to push and hold it out.
any ideas? Im thinking some kind of air cushion and pump it up firm or past the metal "memory point" and see if it stays out.
Thanks.
hi_ryder
Donating Member
Pascoe Vale South, MEL
its not that easy. metal has a memory up to a point. id be getting a pdr quote involved if i were you. they will be able to tell you if its pdr possible or not. otherwise its going to have to be repaired conventionally.
post pics
