DUMPD_VP_CALAIS
- Aug 17, 2004
- 145
- 0
- 0
- Age
- 40
- Location
- Adelaide
- VP Calais
hi my car this morning (engine dead cold) started ok then the idle became erratic. the idle would go down to 500 then up then down again. once or twice it would stall because the revs got so low, but would start up straight away afterwards.
i changed the crank angle sensor couple of weeks ago. The computer diagnostic check showed oxygen sensor faulty...what do check / replace??? any ideas??? i let car run for a bit until the fan came on and the motor got some heat, but still the idle was stupid...For a while now though, after a minute of driving the car when its cold id get the engine warning light come on for about 20seconds - thinking it was the O2 sensor i didnt take much notice cos the car still ran ok with decent mileage...
while the car was idling bad:
-i hit the fuel tank from underneath thinking it might be the pump
-moved around the leads at the coil pack
-moved around the oxy sensor a bit
-checked to see of all injectors working ok
but still it wouldnt idle right.
the engine revs seemed to go up a little then down a little. when i start the car it idles fine for about 3-4 seconds then it starts idling weird
when i drive the car the motor misses pretty badly.
i cleaned out around the IAC valve in the TB a bit, but still not much change. spark plugs changed about 10k kilometres ago.
I dont think its the O2 sensor, or throttle body. I reckon it may be the coil pack because the engine is missing pretty bad. When i got to start it, the revs seem to struggle to go past 500-600, but when i accelerate a little the idle increases (rough as, not smootly)...
