serpentine belt change
te_rarawa
VZ SS & VF SSV Redline
hi guys, how hard is it to change the serpentine belt? mine is squealing like crazy, sounds like a big blower under the hood.
need help asap plz
axemurderer101
Albany
forums.justcommodores.com.au
VY SS
easy as you just need to remember how the belt goes around the pulleys so it pays to draw a picture of it, all you need is a spanner or somethiing which goes on the tensioner pulley bolt then get some leverage to turn it anticlockwise and the belt should get loose and you can pull it off.
_R_J_K_
Zenki S14
To OP, make sure you make a note of this, the tensioner bolt has a reverse thread. Turn it the wrong way to hard, you will snap the bolt.
te_rarawa
so which bolt is the tensioner bolt? i shud get a service manual book
axemurderer101
Albany
VY SS
found this for ya
te_rarawa
i know the 1 mate. cheers for ya help, will b back if i have trouble
kennybear
Ryde Nsw
2006 VE Series V
Quick tip ! I always keep a map of the belt set up,in my wallet. You could be stuck anywhere, if your belt goes. A spare belt isn't any good if you can't put in on. Cheers !
RX25SE
Real cars are steel cars.
MY07 Liberty 30R Spec B 6sp wagon
A 'blower' type noise may be a faulty pully bearing rather than the belt itself.
nathanVY
such boost
Geelong, VIC
2003 VY LS1 Turbo Calais, 2005 4Gen Liberty Wagon
This is true, I had the same issue. Although I was more worried about engine bearings. Commodores usually don't grow blowers on them overnight unfortunately :(
All my idler pulleys were screwed. Fixed the noise.
