Service Engine Oil Message
A9L
Donating Member
VZ Calais LS1
Yeah, pretty self-explanatory. Just curious and wondering what sensor (if any) triggers this message or if it's a timed software thing.
iceman66999
KSA
VZ 2006
It's not timed
And whenever this sensor is triggered, that means you need to change oil or in some cases that the oil is strange
Where the sensor is located : i dont know
But if you change oil you need to remove the warning message
And if you start your car after deleting the message, and it appears again, well ... You have to check the sensor or even the oil that you used
Tro
Brisbane QLD
VZ Executive - VF SS
I just changed mine, though I didn't have that message .... sounds like the sensor is working...?
Check oil level and oil/filter ...
if all OK even check your oil pressure? ... oil pump?
The sensor is located near the base of the oil filter canister...
Tro
A9L
Donating Member
VZ Calais LS1
Interesting, many thanks.
rambunctious
Alexandra Headland Qld
VZ Executive Wagon
