C
clubbie_50
Guest
RKZ234 you said in a message (**IF YOU HAVE EXPERIENCED UNEVEN REAR TYRE WEAR WITH A VT or VX 1 AND HOLDEN REFUSED TO OR COULDN'T FIX THE FAULT UNDER WARRANTY, THE A.C.C.C. WILL LAUNCH AN INVESTIGATION, IF PEOPLE COMPLAIN ABOUT IT OR ANY OTHER FAULT. SO STAND UP AND MAKE HOLDEN ACCOUNTABLE! ** ) I think everyone with a vt xv are aware of the IRS tyre wear situation, I personally thinks its a lost cause trying to get something done with warranty.
I understand how you feel tyres are not cheap if I were you I would just go by a rear camber kit for your car and fix the problem yourself. That tyre wear issue is the same for all us vt vx owners if you lower your car you make it worse, there actually is no fault with the suspension. Like everything they always improve it in later models eg vy onwards and in vx sII clubsports
when they upgraded the IRS. Anyways good luck I think you will need it.!
