Spark plugs
Silver07ve
22
VE 3.6L Omega
Oil changes every 5000-7500.
5W-30 or Penrite 5W-40.
You can do a spell of 1000-2500kms of diesel oil, the same viscosity. Change the filters every 500kms.
If the cars service history is in unknown, it’s a good idea.
The extra detergent’s in the diesel oils break down and clean the carbon from a poorly serviced Alloytec motor.
Filters can be bought in bulk packs on eBay.
I also just changed the oil and I’ll look into using some diesel oil to clean my motor and I’ll try find the filters in bulk!! Thanks heaps
Silver07ve
22
VE 3.6L Omega
Yeah I got the 2mm and 3mm drill bits like it said to do when I did it!
Yeah. Good. But the modification will reduce the schmutz in the intake. If you did from another source, and arbitrarily drilled out the PCV it will make the problem worse. The holes have to be drilled out to a very specific size.
Silver07ve
22
VE 3.6L Omega
The grot in the plenum etc will be from the poor design on the factory PCV sizing.
Oh alright I wasn’t sure if it was just how they are over time or if I had a problem
