Speedometer Calibration Required?
Crawf
South Australia
Holden VZ SV6
Just upgraded from the stock 17's to some new 19's :D, do I need to get my speedo calibrated to read correctly?
PaulSV6
CHE Tuned 156.8rwkw
Castle Hill
VZ SV6 M6, MY10 VE SV6 Sportswagon & MY03 XC SRI
Yes u will, as the rolling diameter of the wheels has increased.
Jesterarts
Your freedom ends where mine begins
2010 Nissan X-Trail ST-L
No, provided the correct tyres are fitted.
Jonesy484
OfficialChadyMeetOrganisr
Melbourne. Victoria
MY12 VE 2 SSV REDLINE WAGON
No he will just need to get low profile tyre. 245.35 R19 should do
Crawf
South Australia
Holden VZ SV6
Thanks for the info, I have 245.35 R19 on so sounds like i should be alright, may check to see how much a calibration would cost anyway because most of the time my digital display and needle speedo read differently. Cheers
88GreenVN
Next Exit Left
60
Surprise, Arizona
Dodge Ram Van 1500 5.2 V8
The PPK number will need to be changed for the speedo to be spot on if you have changed the overall size of the wheel (how tall it is)
Jesterarts
Far out people, why to try and confuse the bloke.
The PPK only needs to be updated if the overall rolling diameter is changed beyond the legal increase tolerances.
From memory the increase is 15mm increase to the overall rolling diameter.
With the fitment of the correct tyre size, the OP will not needs to worry about getting the speedo calibrated.
Changing the PPK will also not change the discrepancy between the needle on the guage and the digital speedo.
Based on my calculations, the tyre the OP has used will cause the speedo to show about 1.7kmph slower than he is actually travelling but considering the speedo from factory has a 3kmph odd tolerance he's all good.
nathanVY
such boost
Geelong, VIC
2003 VY LS1 Turbo Calais, 2005 4Gen Liberty Wagon
Jest is spot on.
The correct tyre profile, will not alter the speedo by more than about 2% at most...
The correct tyre profile for 19s on a VZ i 245/35/19 - will need to comply with the load rating on your car as well which should be around 93.
showbags
SENIOR EL'BAGO
VT Calais, BMW 135 m sport
I've got 20's on mine and speedo's still spot on.
Mavericks Choice
NSW
VF2 SSV M6, VF2 LS3 Calais V, VZ 6L M6 Crewie
Jest is correct, if your really concerned have a mate observe your speed using a GPS whilst holding your car @ a set speed, done mine when going from 16" wheels to 18" & no problems.
