split cable
D
Davin VP
Guest
OK another problem im running 2 6x9's off a sony xplod 222w amp and the power cable from my batt has a split in it some where what would be the easyest and cheapest way for me to replace the whole cable or to locate the split and fix it
cheers
gibbo
Toyota Hilux 3.8l vs v6 & 4L60E
To locate the split you will need to pull the whole cable out anyway , why do you think it has a split, is it blowing fuses?
D
Davin VP
Guest
yeah its blowing every fuse i put into my amp, i went to strathfield car audio and they said it was a split and its 100 to get it rewired and i dnt have the money could it b something else???
gibbo
Is the fuse at the amp end or the battery end?
D
Davin VP
Guest
fuse at the amp i replaced the battery end 1 and its ok but its the amp fuse
gibbo
your amp is fried!
1uzVN
41
VE GXP Maloo A6 317kw
sounds like that
it should blow at the other end if the whole cable is shorting out
