SSV Work in Progress
dmacey
Somebody, make me upset
SSV Series II Sedan Manual & a VK in the build
dmacey
dmacey
As it turns out, the 2.8" pulley is 8ps!
I can't win with this engine, anyway back on 98ron and making almost the same as E85 on 7psi.
Made 380rwkw, 824nm what to do now? Me thinks coils.
ephect
Donating Member
VS Acclaim V6
#### man, time to run that belt on the bearings, screw the pulley
How's the other mods coming along?
phat_6ltr
muswellbrook
2007 VE SS M6
380kw is nothing to sneeze at bro, I'd be taking it to the track to see what your time and top speed is and go on that. I've been told I have 430kw on a hub dyno but I know by feel its a bit out..
Different tuner maybe, what's it drive like?
dmacey
The plan was to crack 400 on 10psi. For some reason going from a 3.4 to a 2.8 didn't achieve that. For every .2 you drop you gain 1psi apparently. I changed 4 belts to make sure the tension was spot on as the rpm goes higher but no win. Other mods, wheels went on last week running 275 on the rear now which helps. Splitter and body modes are on the back burner until after coils. They should arrive in a few weeks.
I'm heading the Heathcote on the 15th to run some times, it drives good, has plenty of pull, not as snappy as when on E85. This is my third tuner, happy with the result just disappointed with the pulley.
phat_6ltr
muswellbrook
2007 VE SS M6
Furry muff..
I was told to go a bigger harmonic balancer not a smaller blower pulley to reduce belt slippage, might be an idea?
dmacey
Can change virtuality any pulley to change boost levels. Belt slippage won't really come into it until your above 11/12psi. Then change to 8 or 10 rib.
This was the quickest and easiest option to increase boost.
Talk to Magnuson now to get there take in the situation.
dmacey
Because you can
DSLXIK
VZ SS 5.7l
are they bmw wheels? or are they something aftermarket?
not liking the blue
but looks alright
