Stability control turns off
bailzski
Australia
VE
Hey guys had a look can’t and can’t find results. When on the freeway going 100+ at times my stability control will turn itself off and it won’t let me turn it back on. I get no engine light and it resets when I restart the car. Only happens on the freeway. Cheers.
losh1971
North Tas
VE Series I SS Ute
Try disconnecting the switch. If it stays on and doesn't switch off then the switch is likely faulty.
Fu Manchu
WA.
Stability Control is often one of the first systems/circuits that get dropped by the ECM in a low voltage condition.
I’d be checking the charge circuit and battery health.
Battery World can do that for you.
krusing
Melbourne, Bayside
Alternator is either over charging, or under charging,
The first signs of failing when your out the BFN,
and will be the most inconvenient time and/or location.
There are 3 main consumable items of an ICE to start and run,
Battery,
Alternator,
Starter Motor,
If any one of these fail!
I don't really need to answer this!
But "Up a Creek" first comes to mind!
