steering colum urgent
shonky12
hi
just wondering how to remove the shaft that attaches the steering column to the rack in a vt holden because a steering column needs replacing and need to know how to remove the shaft that attaches the column to the steering rack
thanks
Kunu
chasing the big 300!!!
forums.justcommodores.com.au
97VT SSsuper6(179rwkw),daily barina,2008 VE Clubby
best thing you could ever invest in is a service/repair manual for about$30..tells u how to do alot of stuff m8,its also got a section about how to remove ya steering coloumn..to much to write on here lol
shonky12
just want to know how to dissconnect the steering shaft from the steering rack and how to dissconnect the steering shaft from the column need to know as it may get done tomorrow
Kunu
theres a little nut that holds the steering column to the rack, tryin to get a pic of it hope it helps m8
shonky12
ok that helps
how do you dissconnect the steering shaft from the steering rack, would like a exploded diagram if its easy as im probably going to start ripping it out tomorrow
Kunu
Not to sure m8,as far as i can see the steering shaft comes out in one piece with the column...you might have to take a look once its out to see if ya can seperate them,sry cant help ya more..
Had a look in the manual but doesnt say either about seperating the 2.
shonky12
ok just wanted to know how to remove the steering shaft from the steering rack to take the column and shaft out as one
lein
Comrade Commodore
Tropical QLD
VC 202/4sp
The steering rack should connect via a yoke to the steering. Should be as simple as removing a locking bolt and sliding the splined shaft apart as you lower the steering rack. May take a little convincing if it is corroded, but off the top of my head at this hour that sounds about right.
Kunu
under the vehicle,remove the steering shaft coupling to steering gear pinion clamp bolt and nut.Discard the nut and remove the clamp from the steering gear pinion.
then inside remove the bolts from the steering column lower bearing housing.
remove the bolts retaining the steering column mounting bracket to the dashboard,withdraw the steering column assembly from the vehicle.
Bit more info for ya...
