DAZ88P
- Jan 15, 2010
- 102
- 1
- 18
- Location
- Caringbah, Sydney
- VF SV6 Wagon
Hi All,
So have replaced all my shocks with KYB's along with strut tops and bearings at the front. Driving much nicer now but having an issue with the new boots and bump stop arrangement.
The day after doing them I noticed that that the boot had come loose from the top holding arrangement which can be seen in the photo attached (I think it is a crap system compared to the original zip tie at both ends). It is basically a plastic ring which inserts into a recess in the rubber boot. After seeing this I first checked the KYB website to confirm the BSK003 bump stop and boot kit was correct, which it is. So I thought I may have secured the bottom of the boot to high up the strut base and when compressed it had popped the top out of its recess so I moved the bottom of the boot down as seen in photos attached.
However it has now popped out again so before I go and do it a 3rd time was after some advice. So if anyone has had experience with these before, should I be securing it even lower again? or should I just flick these and get the holden boot which zip ties to the strut at the top and bottom?
