SV5000 GTS 5000i and Group A brake caliper 330 adaptor specs wanted!
UNLEASHED
Choose your weapon...
Sunshine Coast, QLD
MY12 VE2 CALAISV/ VXSS/VP SENATOR #021, K4 GSXR600
He mate if you see this early enough can you also measur the bolt hole offset aswell??
UNLEASHED
Sunshine Coast, QLD
The measurement at the pencils? If you could??
UNLEASHED
Sunshine Coast, QLD
UNLEASHED
Sunshine Coast, QLD
Hey @ephect can you straight line centres of big holes, and straight line the centres of the small holes, and then measure the distance between the two straight lines.
Lol...that was my next question...
ephect
Donating Member
VS Acclaim V6
I reckon Im going to do a 3d printed plastic template to start with. We've got a 3d printer at the library a couple of kms away for trial fit... :)
I like this idea
So, just to clarify, this spaces the stock caliper out/offset to suit the larger 330mm rotor? Do you have a picture of this bracket/caliper bolted up?
I'll have to get this next weekend sorry gents. I've moved all the crap back into the garage.
Let me see if I can get you something shortly from the other photos I took
ephect
Donating Member
VS Acclaim V6
This was my previous 'template"
You have the bracket in the background. Can you measure that?
Post 24
I know this won't give the distance between the two centres. But this will keep the progress moving
UNLEASHED
Sunshine Coast, QLD
Post 24
I know what you mean..Exactly! I did have them offset by 20mm(330-290mm disc diameters÷2 for radius), thinking both caliper legs have the same reach but they dont so going toward a trial and error but if I can get the distance closer to the money Ill go with that.... :)
UNLEASHED
Sunshine Coast, QLD
I know what you mean...I did have them offset by 20mm(330-290mm disc diameters÷2 for radius), thinking both caliper legs have the same reach but they dont so going toward a trial and error but if I can get closer to the money Ill go with that.... :)
Btw that was a massively crappy example- Version 1.0...lol.
