TH350 into vh reverse sensor
Billy3610
44
New Zealand
1984 VH commodore
Hey
Just getting everything sorted to put a carby 304 with a th350 into a vh commodore but need to know what reverse sensor I need to use as it is blocked off with a bolt on the side of trans … if someone could post a picture or part number thanks
gtrboyy
vt ss & lc gtr
Inhibitor switch on stock shifter?
Billy3610
44
New Zealand
1984 VH commodore
When I pulled 202 & trans out there was a wire from loom to trans & I was told it’s a reverse sensor?
But I looked at my TH350 & there is a bolt where I think sensor suppose to go?
gtrboyy
vt ss & lc gtr
Trimatic had a weird earth usually lost or taken off...other wire if got power probably from kickdown switch.
Look at shifter see if still got inhibitor switch reverse is in that...no idea if your th350 has kickdown switch or vacuum operated?
Billy3610
44
New Zealand
1984 VH commodore
Looking in my vh service manual says it’s the wire to the Detent solenoid so not sure I actually need it?
My th350 has kick down cable …
