Not sure what wattle you have where you are but wattle is a soft wood here. Yes it's acacia family but it's a soft wood very light and easy to split. If left in the weather it rots within 12 months.
Yes well done Losh, Tassie strikes again
Did a bit of research and it seems Tassie has a lot of mimosa wood part of the acacia/wattle group and yes your wattle is soft/ter than the mainland.
From web @ Although classified as a hardwood, the wood from the mimosa tree is about the same density and hardness as pine.
I was mainly referring to the Cootamundra/blackwood wattles which are common here and NSW/VIC. Both these and other proper acacias are very heavy and dense, the blackwood grows like a weed all through Adelaide hills to down south. Once a year I go up to Upper Sturt and collect/clear them from friend’s properties for firewood, which I mix with SA plantation bluegum, works well in my heater and oven.
Coming from SA you should remember those leg size black burnt twig trees with sneezy yellow flowers all along the roadsides and reserves, that”s the hardwood acacia blackwood that was used to make expensive blackwood furniture/kitchens, it burns shithouse but gives off more heat than redgum and is so dense and almost no moisture inside you only need to wait a month to dry completely to burn.
