Tranny is staying in Drive & not going back down in gears up hills or when stopping.
Customcarmods
51
Warners Bay NSW
VS 95 commodore
Got a problem with a holden astra needing to turn car off & start again to reset drive from getting stuck in 4th.
Only doesn't change back gears if it reaches 4th. On rare occasion it will. Check engine (car with spanner)
Comes on when it reaches 4th.
Would they be electronic solenoid?
Immortality
Staff member
Sth Auck, NZ
Thread moved to the Astra section!
VH3300
VY Acclaim
Did you resolve the problem? I've got same issue, code was for trans speed sensor. You can manually shift 1st to 3rd but no overdrive 4th. Careful with the shift down because it doesn't slip through the gears.
