i have done several rebuilds on the 4l60E, the most common probs they have is the main servo piston cracks, the trans pump bushes flog out and the spools in the valve body leak, dont mess around with this auto, they have a tendancy to bite you in the arse, if it slips in any gear, pull it down and FULLY rebuild it, including torque convertor, test the solenoids, with an ohmsmeter, replace every bush, measure sun gears, replace every friction and check 4 hot spots on the steels, replace the band and put corvette servo inplace of stock servo piston also get valve body reamed and new 3rd/4th spool. I love holden, but in my opinion this auto is ****, i rebuilt a vy one the other day that only had 100,000kms on it, do a manual conversion, much better option.
