Hey there again,
Just an update on the Stato,,, I did the T5 conversion, and it's heaps better to drive than the auto, but the engine light comes on intermittently and it did the same with the auto. On doing a code check it comes up as code 24 (was the same when auto was fitted) and as far as I can understand, this means the VSS (Speed Sensor)
Having a thourough read of the book, there's a series of checks to perform,,, these check the speedo, trip computer and ecu?
When I did the conversion I swapped the VSS diode with the one that came with the T5 coz I knew the one from the auto showed as faulty, or no signal. The trip computer test shows no fault, the speedo seems to work, but I was suss on the ecu, so fitted a reco one. It drives smoother, but code 24 still comes up. I even put a brand new IAC & TPS in.
It seems weird that the VSS code keeps comming up,,, yet the speedo etc seems to work fine,,,, is this a common fault & should I bite the bullet & go buy a new VSS?
