Transmission Temp Guage ??
guss
GolD Coast
users.bigpond.net.au
VN Calais
has anyone heard of this being possible ??? after i just replaced tranny, i wanna know exactly whats going in there.
xcop5l
4th year spanner spinner
ol' geelong vic
VN ex cop 5L
you can get the gauges from auto shops, they wont tell you whats going on in the auto but they will tell you what temp its running at
Immortality
Staff member
Sth Auck, NZ
seeing as you have just spent a fortune on gettingyour box reco'd if i was you i would be investing in some extra protection for that box. i'd install a remote oil filter in your cooler lines that filters the same as the engine oil. the standard filter in the tranny is only ofthe screen type and isn't really going to keep small particles outo the transmission fluid. i've added a pic below of the remote filter i've got comming for the missus VS. as a bonus the remote filter mount has a 3rd 1/8" port thats perfect for a temp sender so you can mount your trans temp gauge. i'd also recomend fitting a external trans cooler ifyou haven't already done so
FXST01
The Grey Man
Perth, WA
VP V6 Exec
I'm planning on doing this but with a dual remote filters and thermostat.
Immortality
Staff member
Sth Auck, NZ
heres a chart on tranny life expectancy and temperature. you can see the hotter it gets the quicker it will die. good reason for that big external cooler
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Immortality,
Do you have a bigger copy of this graph?
Nevermind, i just used the TCI in google and woolah
guss
GolD Coast
VN Calais
yer i already installed a 6x12 inch cooler just behind the grille, i might look into that remote filter / temp guage setup thou, thankx for the info.
Furious_8
VC Twin Turbo, VN Turbo, VY Storm
I would not recommend fitting a in-line Oil Filter. As the trans only sends a % of fluid to the cooler it would not filter all oil. But as the cooler only sends a % of oil through the cooler it has to cool as best as possible and a quickly as possible. at idle in park the cooler must flow 1 Liter every 15 seconds. If it flows 1 liter in 30 seconds there is a problem with the cooling system. You could install as many coolers on as your want but if the flow drops its a wast of time as the cool oil is not getting to the trans fast enough.
Immortality
Staff member
Sth Auck, NZ
i shouldn't see a problem with installing a remote filter, the filter is huge compared to the engine filter (fram ph8a, the same i believe as the ford V8 engine oil filter)so no doubt it has really good flow and ATF is much thinner then regular engine oil so it should flow well enough, i doubt it's going to reduce the flow by much at all through the cooler. even if only 1/4 the oil at any one time is flowing through the cooler as the system circulates the fluid it's all going to pass through the cooler/new filter at some stage and thats got to be better then just the screen filter in the tranny sump which really isn't going to remove jack from the fluid really
