Blue-Chip
- Nov 3, 2005
- 100
- 2
- 0
- Age
- 59
- Vt Commodore
muvro said:G'day Lou,
Yeah I have been doing a SHITE load of homework. I just ended about 3 yrs of research on the L67 making up the inter cooler setup etc. Then when the piston let go (previous damage not from the last setup) it was time to get serious... LOL
Yeah I already have the cam. It's a custom ground cam. It's got a max valve lift of .574" and LSA is 115.8. Advertised duration is 274 degrees. All these are inlet figures. Ex is slightly different.
Yeah the turbo isn't set in concrete yet as I am going to wait till I port the heads and inlet manifold and get it all flow tested before I actually purchase the turbo. Also once it's all flow tested it wil give me more of an idea on what sort of hp I'll be able to aim for, making it easier in selecting the correct turbo. It's either going to be a GT35r or the TO4z.
Yeah gate duties wil be done with a Tial 44mm. I am just going to use a mech boost controller to get it all running. Then later I'll prolly invest in one of those E-boost 2 controllers.
Again not sure on the exact turbo specs yet. But I am pretty certain I'll be around the 1.0 mark. Although I do want it to have around 12-15 psi by 3k. SO I might have to go a .8 if it's too laggy. Either way it's going to have a huge stall in it.. LOL
I'll be making the ex manifolds etc. I haven't worked out the exact specs yet as there are a few other things to do before I get there. I'll also be making a custom upper inlet manifold ontop of the slightly ported and polished VX lower IM.
Thanks for the encouragement!!!
It's going to be a long road but I plan on driving my car from my wedding next year. So I have a fair bit of time up my sleeve to amek sure everything is going to be perfect!
Gotta help the old man first, and finish the race car we are restoring. Then it's full time on my car.
Thanks and I'll put up a thread on the build when I get stuck into it. Keep you updated!
Tark
WIZZA..........:thumbsup:
Well it shows your knowledge on the subject...... :bang:
Before you mouth off, you might want to find out a little about the person you are mouthing off at first...
Also a little more reading and absorbing will take you further than useless posts like yours...
Don't like it don't comment unless you have something constructive to say!
Tark:whistling
G'day Tark,
I have heard a lot about your supercharger adapter plate and I am sorry to hear It's gone in the direction it has.
Regarding you turbo set up, it all sounds good, although when one looks at a
pressure map of a GT30, GT35, and a TO4Z in reality the pressure maps tell
me that when running a reliable boost pressure these turbo's are only running
in the 50 to 70% efficiency range, so really overkill unless used with a strategic
build plan.
The 44mm Tial gate KILLER unit.!!!!:w00t:
From my experience Tark a .63 turbine housing is fantastic on larger style
turbo manifold, say on a GT30, GT35 however with my own manifolds which
are fairly tight a .86 turbine housing is ideal with awesome throttle response
and no turbo lag what so ever. Just a bit of food for thought.
I have not had much to do with the e-boost controller so I cannot really
comment on it, the setup I am using for boost control on these PumpAction
Kits is all done through Kalmaker software using custom scripts specifically
written for this setup and setups alike
Boost is controlled on Air flow through a larger 75mm MAF which has extended
look up tables that go out to 512grams per second, this is enough air flow
metering for 400+ rear wheel horse power.
The way this works is as follows.
You have six tables in the software, from first gear to sixth gear.
On these tables in each gear you have Air flow vs rpm that have also been
extended to 8000 rpm from there original 6800.
Now to control boost all you need to do is tell the software at what airflow you wish to open your waste gate, allowing a separate boost level at all
the different RPM points. this allows you to run different boost level in each
gear as well as RPM, and best thing about this setup is that you can actually maintain lower levels of boost around maximum cylinder fill & cylinder pressures
generally where maximum torque occurs, which I feel is good insurance that you don't rattle you engine to death.
So like i said previously, keep up the good work and if there is anything that I
can help you with, just yell out on here or my own section or maybe even give us a call sometime as the quality of some conversation can be well
rewarding.
Cheers Lou.
