Twin throttle bodies
Liam85
Holden VF ssv ute manual
had anyone seen this video lately of this VE ute with twin throttle bodies?
I think it looks bad ass for a N/a but I was wondering what the legalities of it are. I saw photos of heaps of cars at Summernats with similar setups but never seen one on the street. I'm guessing this is because this wouldn't be a street legal mod if I'm right?
Bigfella237
Far South Coast of NSW
More cars than I've got space to park!
Can't even see that video, put it up on a real host that DOESN'T require me to "sign up now" to see it...
monstar
Naturally as-pirated
56
depths of Hays Inlet
facebook.com
Peugeot 207 GTi
Having a part of your engine sticking 6" out of a hole you cut out the top of your bonnet is the give away. Cover that with a legal cowl and your field of vision is impaired. Then there's emissions.
For what, 40 bhp? Pose mod.
Towcar
Auckland NZ
VX Berlina Wagon
looks like more wank factor than any real gains.
The issue is that you introduce changes in the air flow over the car, it could be theoretically possible that the second filter actually has air sucked out of it! In my VR4 days people were getting the evo vents put on with a vent cut out for a pod filter, the theory was to allow fresh air in, the issue was it didn't work as the vents were not in the right place to draw air through the vents and actually mean hot engine bay air was being circulated to the pod filter the solution was to replace it with the factory airboc which was a similar design to the OTR that a lot of people use on the commodores.
lmoengnr
Donating Member
Sunbury Vic.
MY12.5 Maloo R8, MY12 Redline ute, Magnum 224
Dunno about NSW, but in Victoria you will be defected for 'obstructed vision'.
OzTurtle
50
Seaford; VIC
VF II Redline
If you're looking for something a bit different, have a look at the Harrop Hurricane set up. Looks mint, but would need more cubes to justify. 1 of these on a stroked bottom end would be killer!
Bigfella237
Yep, with most cars you get high pressure at the leading edge of the bonnet, then a lower pressure area toward the middle of the bonnet (where some, like Walkinshaw for example, have vents to suck hot air out of the engine bay), then another high pressure area at the base of the windscreen where the cowl panel takes in cabin air.
Andrew
