Fu Manchu
- Mar 18, 2006
- 18,060
- 22,847
- 113
- Location
- WA.
- VZ Crewman, VZ Cross 8, & ya mum.
I’m starting to put thoughts toward those components in the Cross8.
Not sure if replacing those for peace of mind is the way to go. The motor will be getting a refresh later but not straight away.
So I’m guessing without a big cam, the dual valve springs are woftam. So what’s a good brand to look for in a single valve spring?
Crow, VCM I’m going to guess are good enough?
Is there a type in particular worth looking for?
Pushrods, I’ll pull them out to inspect them, but what hardened or heavy duty ones are worth looking at?
I’ve seen two types of trunion upgrade kits. One with the brass bush, and one that keeps the needle bearings but securely. That’s the one I’m probably best looking at?
I’ve only driven this twice. It‘s internals are completely unknown.
It will be a daily and do a few beaches, so some revs involved with the soft sand. Stock does it pretty well from what I’ve seen but I’m a bit nervous about the rockers.
