[QLD] VC-VK K sport coilovers Brand new
OFF T4P
Donating Member
townsville
383 HSV GTO coupe & vk ls1 turbo
ITEM: Got a set of brand new k sport coil overs to suit VC-VK front and rear
PRICE: $1500 ono
Will post or can pick up
Paypal or bank deposit
CONTACT DETAILS: 0400686249 for info and pictures
From the website
Ksport Kontrol Pro Fully Adjustable Coilover Kits provide the ultimate in suspension technology for your street or track car. 36 levels of dampening adjustment allow you to fine tune the ride to your handling and comfort needs. The dampening adjusts compression and rebound simultaneously for ease of adjustment. Pillow ball top mounts in the front and rear on some applications allow you to maintain vehicle manufacturer suspension geometry design. Key Features: 36-way adjustable dampening Made from high quality 6061 Aluminum with T6 for increased hardness Compression/Rebound adjustable Adjustable spring perch for height adjustment Adjustable body allowing maximum suspension travel Monotube High Pressure Design reduces oil leakage Electroplated body for protection from corrosion and rust One Year Limited Warranty Most applications utilize an adjustable lower mount, which means you adjust height without losing suspension travel like some other coilover designs do. With the mounts and most pieces of the coilover being designed for 6061 billet aluminum the kit is lightweight, durable, and rust resistant. The steel shock body is electroplated with zinc to resist rust and the elements. The valving of each set is matched to the springs installed for unmatched ride quality and reliability. The Ksport system uses a Monotube design in which the oil and gas are separated within the cylinder. When compared to twin tube designs the Monotube dissipates heat better, allows finer dampening adjustments, and requires more expensive design process. Aeration and cavatation are a lot less common in a Monotube design, which results in a better ride. The Ksport Kontrol Pro Coilover kit has been designed with professional road racing in mind offering extremely high value and performance.
OFF T4P
Donating Member
townsville
surly someone wants some coilovers in there early girl
bfhoon
Australia
vx commodore
Hi there
Would you sell just the fronts. Pm me cheers
