VE Air Conditioner
dale762308
Northern Victoria
VE Omega V Series LPG
Have had new car for 1 week and A/C does not work all the time. Sometimes you can get it to work others not, when you press the A/C button the ReCir light comes on.
Holden know of problem but are "working on fix"??
Spend $39K and live in centeral Vic and no AC, not impressed, anyone else have same issue?
:ranting: :ranting:
andrewmac
37
S2 VE SS
Yep my parents SV6 has this issue.
Apparently its a switch or something and havs happened to a few ppl.
I took it up the coast yesterday ( 1 hour 110 km/h) and it worked the whole way.
But round the city its fan speed goes all over the place and occasionally ciuts out all together>
We have just added it to the list of problems that now have to be fixed (handbrake, centre speaker and the seatbuckle recall).|
But although these issues are present the car is still greaty and we did expect a few niggles.
I realise it ia a royal pain in the a**e but its all part and parcel of a new model car.
Super Coach
GTS, S, CV8Z, SSVR
GTS, S PAK, CV8Z, SSVR, CALAIS V, MSE
i took and SV6 for test drive and i wanted the air con on and would you guess it the AC played up right in front of the sales guy. i think he tried his best to cover up the problem but in the end ended up big red faced
Scotty_Doesn't_Know
Don't Tell Scotty...
Canberra, ACT
Holden VE Calais
Apparently it's not a problem with climate control fitted cars... Can anyone confirm this at all?
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
its a problem with climate cars as well. there is a different HVAC module available to fix it, tell the dealer to read the bulletins
Rob
mjm4676
47
Lennox Head NSW
VE SS Ute, 94 Swift Cino
Your local dealer should have the revised HVAC modules from SALMAT, so go in and see whether your vehicle is flagged on system for replacement.
herkman
84
Bridgetown WA
VE Appolo
ac problems
I have been told by a spy in Holden that it occurs when the fan speed exceeds notch 11.
Shutting the engine down should re cycle it.
We are not having the problem with Nov Build.
Col
Christina
Banned
Almost genuine VT "S" + VZ "SS" Red Ute + Vk V8
ring them up and get it sorted!!
39k... gah! give the man his air con!
