1997 VT Calais Series 1
- Oct 31, 2017
- 34
- 2
- 8
- Age
- 48
- Location
- Sydney
- 2009 WM STATESMAN
If the noise you hear changes when you have the aircon on then I suspect what you are hearing might be external to the engine and not necessarily internal. External noise can sound like it is coming from inside the engine so I would check carefully on start up with the bonnet open and someone starting the engine for you testing both with the AC on and then off. For example a bad serpentine belt squeal on a cold start will sound terrible and will not necessarily be continuous(but often is) and can last only a few seconds or it may go longer until the belt warms. If there is a noisy bearing in one of the external pulleys that only makes a racket on cold start up (for now), that could be something to eliminate as the cause of an external noise although when these pulley bearings start to become noisy the noise is normally continuous.
From what you have posted it does not look like the Holden mechanics made any effort to detect and isolate the noise for you but just changed parts to get some workshop revenue from you. In particular I cannot fathom why, if the engine noise is internal, changing an "oil pressure switch" could actually do anything to fix a cold start engine noise(and it did not of course). The OP "switch" is only there to trigger a low oil pressure warning to the dash and probably a signal to the ECU. It does not do anything to affect oil lubrication to engine parts. Oil flow is run from the engine's internal oil pump, oil pressure is generated by resistance to flow and excess oil pressure is dealt with by the oil pressure relief valve.
By the way, check your owner's manual again on the optimum oil spec for your engine. You mentioned 5w-40 is what you are using. As in the later V6 engines, I understood the preferred oil was a 5w-30 for your 2009 engine. If that is the case I would not be using a 40 weight oil.
I agree with Sean880,
1) If the timing chain was the faulty part then you would have most certainly received a fault code.
If the timing chain was stretched and there is worn timing chain tensioners. At cold start you hear the timing chain slapping against the timing chain tensioners until oil pressure builds up but? Once you have this occurring it would definitely generate a fault code as the timing would not be in sync with the cams and the sensor would pick this up.
2) As for the AC, ( as mentioned by Sean880) I would be inspecting it at cold start up to see if the noise is coming from the AC Compressor (possibly a faulty compressor bearing, but I have never heard or known of one make noise at cold start only) Also check any other component that may cause the cold start issue like, belt tensioner, water pump bearing, alternator etc...etc... but at cold start I think your going to find that it is an Oil related issue.
3) Sean880 is correct, an Oil pressure switch will do nothing, it only monitors and sends data has no mechanical job of the internal engine.
4) Sean880 is correct again, the choice of Oil Brand and it viscosity is vitally important for these engines, 5W-30 is the recommended grade of oil but? In saying that my engine has done 380,000+ km's and is still performing well and I will at a later date move to 5W-40 after checking/testing the compression of the cylinders, but I am definitely using full synthetic engine oil and my choice of brand is Nulon Full Synthetic 5W-30 Long Life Performance Engine Oil.
