Im just puzzled right now, why would the pressure builds up almost immediatley? Should i be concerned? Or its just something not sitting tight?Keep trying the others. See which one works
A blockageIm just puzzled right now, why would the pressure builds up almost immediatley? Should i be concerned? Or its just something not sitting tight?
Are you are applying vacuum to test the cooling system? If so you’d need shut the valve(s) at the gauge before turning off the compressor, else the tool may not hold vacuum. In essence you want to place the radiator under vacuum and then seal the line to the radiator to test if it can indeed hold the vacuum. If it doesn’t hold vacuum then either the valve(s) are leaking, the radiator cap attachment is leaking, you’ve connected the tool wrong, or you indeed have a leak somewhere within your cooling system.Im just puzzled right now, why would the pressure builds up almost immediatley? Should i be concerned? Or its just something not sitting tight?
