Skylarking
- Feb 3, 2018
- 10,155
- 10,658
- 113
- Age
- 123
- Location
- Downunder
- Commodore Motorsport Edition
Modern engines have knock sensors and can cope with poor fuel where the ECU will adjust spark advance to cope with poor fuel and any knock that it picks up.Also, would filling up consistently with special unleaded suffice, or is it advisable to only put in premium fuel?
Holdens LS3 V8 is capable of running on 91 or better fuel. I assume the v6 is the same.
The owners manual specifies “high octane recommend”, the fuel filler flap has a sticker that states “high octane recommend”. GM’s US engine specs state the engine can cope with 91 (or 87, Ron/Mon? can’t remember)… Down under, high octane starts at 95 so it doesn’t even have to be 98. However, Holden states that if you use 91 the engine will produce less power and as such they “recommend high octane for best performance”.
If the car couldn’t run on 91RON they’d be legally obliged to use stronger language like “must use high octane only”. If it couldn’t run on 95RON they be required to be explicit and state “must used 98Ron only”. Holden doesn’t use such mandated language as “recommend” has a very different meaning than “must”.
Basically, the v8 will run fine on 91RON. I assume the v6 is the same.
Obviously a modern engine will make the most out of a higher octane fuel and you’d probably notice better performance (especially on hot days) by using 98 but by no means is it mandatory.
