VF SSV Redline Brembos fit WN2 Caprice?
Nando.
61
Lalor
VF ssv redline.
You don't need 19 inch wheels, 18 inch will fit provided the offset is right The offset required is 48 mm. Even with 19 inch they will not fit without the correct offset.
Yes. That is correct.
As for the rear Brembo it should be ok and the only modification needed is to trim the lip on the dust cover plate.
Willm
24
Holden Berlina
I am guessing the redline cover plate could replace it?
Nando.
61
Lalor
VF ssv redline.
Yeah nice
I am sure that you are aware of changing the roses as they are bigger.
And from memory you might need to change the master cylinder as the bore is slightly bigger.
Jeda
WN Caprice V
I'm told that the wn2 wheels will clear the vf2 redline brembo calipers.
I can tell you for certain that wn1 wheels don't.
Nando.
61
Lalor
VF ssv redline.
I ment the roters
keith reed
76
Raceview Qld
1983 vh v8 sle 2000 vs v8 ute 2012 ve11 redline
Fitting rear brembos is mainly for looks. They do make a difference but it is marginal. Ceramic pads make a difference.
