VN Berlina - Replaced Doors, Need Wiring Diagrams..
Dangerous Dave
Donating Member
WK Caprice
Hey Guys,
Okay, short story long is...
Mate bought a VN S1 Berlina, had all manual doors. Got 4 Full electric Doors of Ebay for $100 :) , been to wreckers, got full loom off of VN Calais.
Have got power windows running, mirrors working but not central locking.
have got wires connected to the looms for permanent 12v, switched from ignition, ground, and door switch .
Now, the question.... central locking wont work... the fuse box says there is a seperate central lock fuse, which means i need to connect another +ve for the central lock to work... so.. i need a wiring diagram for the central lock with allocations to the connectors please..
cheers, dave.
anarklov3r
2007 WM Caprice
the VN's actually had a central locking module that connects to the main wiring loom behind the dash (the same loom that you connect the power window module to). The central locking module sits up behind the glove box. Not going to work without it :)
Dangerous Dave
Donating Member
WK Caprice
got it... have the entire loom and both modules, but still no central lock.
That's why i'm basically asking, do i need a seperate +ve supply for the central.
if so, which connector on the loom plug does it connect to..
Currently have, permanent +12, switched +12, gnd, and from door pin switch
Mayhem05
VN Aero / Liberty RS Turbo / VL Turbo
Heres a wiring diagram for central locking
Dangerous Dave
Donating Member
WK Caprice
nearly there...
Have got windows and central working fine, but i have 2 wires left over from the loom....
This is a view from the FRONT of the plug which is on the actual central lock / window loom...
1 - Switched +12v (Pink)
2 - Unknown (Brown & Yellow)
3 - Windows +12v (Orange/Green)
4 - Central Locking +12v (Orange/Violet)
5 - To Door Jamb Switch (White)
6 - Unknown (Brown & Red)
7 - -ve (Black)
So... if u can help with 2 & 6 it would be great.
Cheers, Dave..
