VN head flow numbers anyone?
geardys
GEARDY
40
Tasmania
95 v8 ute 5sp
they will be the same as VP,VR,VS.
they are all the same in using the L34 valves (1.94' intake, 1.6" exhaust).
except the Vn Group A that had "D" shaped exhausts ports and a thicker dec.
Also the Vl walkinshaw was a different castng altogether.
400 sounds about right. depending on the valve lift
they are more then 110cfm at the intakes and more then 70 on the exhausts. by how much i don't know.
the red,blue & early black heads are 90cfm at the intake and 68 at the exhaust.
greenfoam
102
VP Executive R-spec
Inlet cfm at 25 inches
.1 77
.2 123
.3 163
.4 182
.5 187
.6 188
Exhaust cfm
.1 60
.2 101
.3 129
.4 142
.5 147
.6 150
Immortality
Staff member
Sth Auck, NZ
stock standard the VN style heads flow more that 400hp i believe. they are some of the best heads around from the factory even better than most of the stock chevy small block heads unless you go to aftermarket heads etc. most chevy small block heads uptill the the gen III used the siamesed center exhaust port design. Holden went away from this design with the VN series heads and it's a good product. fit the bigger 2.02 intake valves with a descent port and polish job and there killer heads
sir355
Father Figure
Cairns
VR SENATOR 215, HZ ute
The heads flow well over 400hp, its more around the 450 mark, and the vr,vs heads are slightly different aswell and flow a little bit more.!!!!
Deuce
Super Stock
'94 VR SS V8
Dear admin's
Assuming the above info is still deemed to be correct, is it possible to sticky this to the top of the V8 development section?
It is good info that I have referenced a few times.
And to add to the above info, here is the come590 info
shane_3800
35
places
vr commo
Dear admin's
The Stock numbers are at 25" most people use 28" and also we sort of need to know what bench too.
When I pull my standard set I'll get them sand blasted and flowed then I'll post them in here if it's stickied.
I'll get them flowed on a Super Flow 600 at 28".
Deuce
Super Stock
'94 VR SS V8
Found this on another site:
CFM @ 25" x 1.058 = 28"
Therefore
.1 77 = 81
.2 123 = 130
.3 163 = 172
.4 182 = 193
.5 187 = 198
.6 188 = 199
Exhaust cfm
.1 60 = 63
.2 101 = 107
.3 129 = 136
.4 142 = 150
.5 147 = 156
.6 150 = 159
All rounded to the nearest whole number.
