B
baryscommodore
Guest
Indy_387 said:You will probably find that air only coming out of the footwells in a disconnected vacuum lead.
i had the same problem when i installed my sterio, i found out afta afew smokes what the problem was, one of the pipes fell out. when you install a sterio in a you need to take out the fan controller thingy, n you need to take out all the connectors behind it plus unscrewing a screw which connects to a a metal pipe thing which goes all the way at the back. anyway around there should be afew black pipes which go to the fan controller which connects at the top. where the metal thing goes at the back where the black pipes are it might of fell out there, thats how i got mine fixed. sorry lol i cant explain it properly but i hope it helped lolz
