Vn v8 no vaccume to heater tap plz help
Gmvn5l
34
Heathcote
Vn v8
Code 21 and -30 deg C is an open circuit on the ambient temperature sensor you would have installed in front or the radiator.
25 is an open circuit on the sun sensor in the top of the dashboard.
I don't know if the CC works if the inputs from these sensors is missing.
I don’t remember installing anything in front of the radiator. Only thing that’s there is the condenser radiator that’s plugged in that’s it.
MikeC
VQ Statesman
Have you installed an ambient air temperature sensor and sun sensor at all? I honestly don't know if the CC will work properly or at all with sensors missimg.
Gmvn5l
34
Heathcote
Vn v8
Hi yes installed the sun sensor on top of dash. I know there’s also a sensor that I installed onto heater core pipe the temp sensor or what ever it is. Where is the ambient air temp sensor
Fu Manchu
WA.
It’s located at the front of the car next to the radiator. It’s part of the front loom.
91SS
Holden Commodore VNSS 1991
With a huge restoration like that it could be a bad connection to CC or a sensor or ECU.
Try carefully twisting wires to CC and sensors and push up pins inside ECU plug and see if you get a reaction.
Copper grease on electrical connections that require it.
