james_ryan02
- Jul 15, 2010
- 19
- 0
- 0
- Age
- 36
- Location
- brisbane
- Holden HG Prem / VP commo
The compression looks a bit low, almost boost specs. but if your not going to ever run boost Id be leaning towards the flat top pistons if you can get your hands on a set.
Also, your block isn't factory cleared for a stroker crank, so it will need to be notched out so your conrod cap bolts don't hit the center of the block but its not a big job, anyone can do it even a first timer or you could just buy a VS 304 block as they are cleared for the stroker kit.
Also depending on how hard you want to rev this engine will determine weather or not you should get the rotating assembly balanced, personally I would but I know plenty of people who haven't.
I cant see why you would need to bore the block,unless its pitted from rust but, if its just got a bit of surface rust then give it a quick hone yourself and try to keep the virgin bore specs. You can buy honing tools pretty much anywhere and just look up some vids on YouTube to see how its done.
Also, I cant see a gasket kit that comes with the link you supplied, so there's another $350+...
Have you had a look on ebay for stroker kits? There are some nice kits on there but also some dodgy ones, look at the feed back to get an idea if the kit is good or not, if they are ****, people will let you know.
Awesome info runner, I've been watching a few videos on machining and rebuilding. The notching will be pretty easy. As for balancing, I will defiantly get it balanced.
The car did have flood water stored in it for some time although i did have it soaked in litres of WD40 to separate the water from metal, rust is visible in some places. Im quite certain that it is just surface rust, so I'll just hone it myself. That website offers Flat top as well but with the same compression so ill look around for some more. What ratio should i be looking at?
The engine ran super smooth and perfect prior to the floods, do i not need to worry about getting it machined properly, because i watched this video and it seems theres a lot more involved than just cleaning it out and honing? - How-To Machine a Chevy 350 Small Block Engine (Machine Shop) - YouTube
thanks again
