Before you start laughing at my wiring technique I thought it best to show with pics what I have done with the right hand side switch block wires.
This is the connector that used to connect to the top switch on the old vp switch block.
It has a grey and black wire that for some reason have been joined just before the connector. (this was done before I bought the car). Is the grey wire here the one you are mentioning? If so should it be connected to this black wire or the other black wire shown below?
This is the old vp light switch connector which now has a black wire doing nothing. (Is this the wire that should be connected to the grey wire in the above pic?).
This is how I have my lights wired up at the moment. The only action on the lights that work right now is the full lights. The parkers do not function. That is fine with me at the moment though.
If you are unsure of the colors of some of the wires let me know and I will write them out for you. Thanks again for your help.
