- Apr 15, 2006
- 22,669
- 20,614
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
Sorry I just bought it and I don't know if it did or not . There is no kick down cable to throttle body at all. This vehicle was a v6 column shift auto originally. There is some crappy cut and shut done to the engine loom to original body loom that freaks me out a bit, I did find a local with a vr 5.0 auto engine loom and matching ecu I was nearly thinking of getting , that would with any luck fix two issues but now I'm not sure if it would be compatible .
Well that is weird as I don't think the 808 can control an electronic trans in any way.
Is there a table that lists ecu to auto type and 5 litre series specifically ?
There is, if you go to the PCM hacking forum there is a program you download call Memcal ID tool, it lists all known tunes and ECU/PCM numbers.
You might want to post the photo's of that ECU and Memcal there as there might be someone there who recognises that hardware and branding.
