- Apr 15, 2006
- 22,767
- 20,911
- 113
- Location
- Sth Auck, NZ
- HSV VS Senator, VX Calais II L67
Factory bolts are TTY (and should be discarded once removed), no harm in replacing them with a high tensile bolt as long as it's meets the load requirements. Many folks use replacement ARP bolts because they are re-usable
You need to be careful as some coating processes actually de-rate the bolts due to the heating/cooling the bolt is put through.
There are also different levels of high tensile bolts. Your start with your basic grade 8.8 and then you have grade 12.9 I tend to use grade 12.9 cap screws for the majority of my replacements as they are as good as (if not better than) your entry level ARP bolts.
