VS fuel and temp gauge intermittent
Scottmac276
60
Penrith
VS Maloo
My VS Ute has an intermittent power issue with both fuel and temperature gauges.
I have tested both gauges in my level 3 cluster. Both work fine.
computer system reads correct distance to empty All the time.
any ideas?
Immortality
Staff member
Sth Auck, NZ
It's a fairly common fault for VN-VS Commodores having issues with non working gauges in the clusters which was typically a dry solder joint issue.
Scottmac276
60
Penrith
VS Maloo
I resoldered the cluster board and no change. Is that what you are talking about?
Immortality
Staff member
Sth Auck, NZ
wildfiremaint
VR SS , 2007 Subaru LIBERTY Wagon
There is a small 10V regulator module that plugs into the rear of the cluster that may be your problem.
Check all the solder joints on that PCB.
Scottmac276
60
Penrith
VS Maloo
No this board?
wildfiremaint
Similar function. I guess different cluster versions have differing modules.
That one I showed is from a 1994 VR
