the part numbers are mostly the same its the numbers on the barcode on the plugs of the ecu that tells you if it will work.easiest way is find a supercharged ecu or a police ecu known to have all the circuitry in them. i have posted the barcode list on here before god knows where ill find the numbers for you Kalmaker Forums • View topic - W46 work in a 16199728 PCM
