VS UTE Replace all bushes
AlexCameron23
VSIII CSV BULLET 350
I've seen alot of posts about it but no recent strong answers. Looking for the cheapest front and rear Bush kit. Already found an upgraded ajustable pan hard rod not too much more to buy the new rod with bushes instead of replacement bushes. So any trailing arm z bar options people have found the same would be great. Street ute.. cheap rubber.. DIY job.
StephenM
71
Innot Hot Springs Qld. 4872
VS Equippe Series II
I replaced the complete arms as it also included tie rod ends. $250 for both from (I think) Online autoparts. It was easier than trying to remove and replace the old bushes. Also the tie rods ended were bolted not riveted so easier to replace in another 200,000k. They also have the rest of the bushes.
greenacc
Searching for the billion
VE Berlina
You will need a press or at least a big vice if you want to do the steel shelled bushes at home, otherwise poly bushes like superpro are easier to fit because they slide in more easily.
gtrboyy
vt ss & lc gtr
Pick & Payless on Saturday if they still do $70 on you can carry lol
Find one with rebuilt suspension,swap it all over.
