VT 304 to VS statesman
commo lover
35
strathmore
vt commodore
Hi all just wondering the go if I want to convert vs statesman v6 to a vt 304 roller motor is the looms ecu bcm transmission etc all compatible?
gtrboyy
vt ss & lc gtr
No the vs map based ecu/loom will not plug & play with vt driveline for many reason....if you can get vs series 3 ute different story.
Only real chance of using vt driveline in vs body probably means repinning plugs on drivers side in engine & possibly plug near glovebox.
That is just loom side of it then you have bolt it in so vn/vs engine mounts,headers & pulleys to start with.
