vt codes
adamandtanya
vt calais
just diagnosed my car it comes up with codes 31 and also 92 everything apears to be ok how do i fix this any help would be great
vyssls1
sw only EFILIVE Tuner
Margaret River WA
www.gmperformancecentre.com
310 rwkw Cam VY SS M6 , EFI LIVE Tuner
code 31 Theft deterrent sensor
TROUBLE SHOOTING PROCEEDURE
#1 Ign on use a volt meter check voltage for 3-5 volts at terminal 9 9circuit 1221 (red/black) DLC connector and earth
#2 Faulty PCM
TROUBLE SHOOTING REMEDY
#1 If OK go to next step,if not OK check for open or short in circuit 1221
# Replace
code 92 Low Speed Fan
#1 Check is code 31 present
#2 If engine does not start and code 92 is set,test circuit 1221 (red/black) for earth or open
#3 Check for intermittent fault in harness or connectors
#1 Treat code 31 and test drive
#2 Repair
#3 Repair or replace
fasamr
vt 3.8 ltz
pleasem explain these error codrs
47 18X Reference Signal
Missing
32 Mass Air Flow (MAF)
Sensor Out ofRange
82 1-2 Shift Solenoid B
Circuit Fault
accentstencil
71
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Code 92 will almost certainly be a faulty low speed fan relay.
VTS5
TechJunkie
Sth.East\Melb
VE OMEGA 3.6L Dual Fuel
Missing
Sensor Out ofRange
Circuit Fault
First 32 MAF , if u can try another unit.
VTS5
TechJunkie
Sth.East\Melb
Missing
Sensor Out ofRange
Circuit Fault
Then Code 82 ,Looks like tranny problem,
VTS5
TechJunkie
Sth.East\Melb
Missing
Sensor Out ofRange
Circuit Fault
And now 47 18X Reference Signal Missing; Check or replace Crankshaft Position Sensor, Wiring or Connector.
fasamr
vt 3.8 ltz
How to replace 1-2 shift Solenoid b
guys help me out anyone changed their transmission shift Solenoid's, let me know the complete Procedure of changing Solenoid step by step PLEASE!!!!!!!
I three 3 faults after doing the paper clip diagnose
1. 32 Mass Air Flow Sensor
(No adjustments possible on this component)
Voltage Signal Out of Range
Sensor Faulty, Wiring or Connector
I dont know wat to do with it i bought a used MAF from e-bay and after replacing i get same error no matter dosent bother a lot but need to be fixed
2. 46 Direct Ignition System No Crankshaft Reference Signal
(Received by PCM when Engine cranks)
DIS Module Problem
Wiring or Connector (DIS Module Terminal D to PCM Terminal #D12)
Really no idea wat is it this error.
3. 82 1-2 Shift Control Solenoid Circuit Fault
Solenoid, Wiring or Connector.
This is the Error code which i give more priroty to be fixed First cause i dont have the first gear car Picks up from 2nd gear, i hate that and want to know how to fix it or how to change the solenoid.
Do i need to remove the the valve body to replace it , if yes than i have to get it fixed from some mechanic , if i can do it with out removing any sensitive things it would save me $$$.
i am completely stuck so guys help me out
Ramsey82
1998 Acclaim
How do I get these codes from the computer in my VT Series 1. I seem to have an ABS Module unit **** itself, however, I'd like to see if anything else has gone with it.
Ramsey82
1998 Acclaim
Error codes
I may have found these nifty error codes but how to determine what they mean is tricky. I found that t00 nu or something that looks like that. I get to code 24, 25, 26 and they have this -- next to them. WHAT DOES THIS MEAN?
