Ok well it looks like I am back to the drawing board. Had the car checked out and it is at about -2.8ish it appears the springs have helped a bit however the tire shop said with the lager thicker wheels now it is putting more strain on the rear end and forcing more camber.
Well I guess it's a camber kit or I will have to go buy some stock wheels and put the standard springs back in.. STUFF THAT!!
I am looking at this kit of $155.
4 Point Camber Kit if this is the kit that I need then it seems pretty easy to do I would be able to fit that at home take a look at this thread for fitting.
Rear Camber Kit fitting personally I wouldn't take the link off the end of the car to fit them as it would be way too much work you would be able to do it still on the car.
What do people think of these kits.. I had a look at the kmac one fo $295 and well it is pretty much the same thing going by their photo all they do is give you tool to take the others out but why would you bother? You are not going to need them anymore so I would just hack them up so that you can pop them out easily.
