bazza13
- Jun 22, 2009
- 39
- 0
- 6
- Location
- Auckland New Zealand
- vt ss 5.0
Hi guys ,
I have this SS which I use for weekend cruising been ultra reliable had it for six months.Had to store it one weekend in my sons garage while having some work done at my place, ran sweet algud locked it up and left it. Went back a week later to get it wouldn't start cranked over and wouldn't fire. Ok I got a mobile mechanic around to see what he could find thought it would be easy just to get it underway again. Now did a scan came up with code 46 thought it might be ignition module so he grabbed a refurbished one put it in no go, threw a new dizzy in bang away she went but ran as rough as guts on 7 cylinders only then , he then put some new leads on one of the old ones had a crack still ran rough and that was all I said for him to do at least I can get it home to my usual mechanic. Also started throwing code 49. Got it to my usual mechanic he found one of the injectors had failed
so put in a new set , fine don't mind spending the $ as long as we get it sorted, he also found a broken wire in the loom which he fixed redid the timing and He said take it for the weekend see how it goes let me know, went for a drive seemed a little rough than what it used to be stopped at the lights and the oil light came on, pulled over and oil all good full as normal, oil sender fault related to electrical problems???? Maybe coincidence??? Also car pulls like crazy heaps of power only when idle or low revs does it feel rough, only thing hasn't been done is the coil. Any advice would be appreciated going back to talk to mechanic tomorrow , by the way this mechanic is a good guy even took the car home to his place to work on it at night and put a lot of effort in to sort it out, many thanks in advance for any ideas
