dodgie12
- Sep 5, 2012
- 10
- 0
- 0
- Location
- Gold Coast
- VT Berlina Station Wagon
Thanks all for your help.Think we have it all sorted after getting the wiring diagram. Am a bit mad with myself looking for something complicated and it wasn't. By shorting the high fan speed relay 30 & 87 the fans kicked in and seemed to me to run at the same noise level as when they used to kick in when the a/c was switched on so I assumed the fans were ok and went looking for all kinds of non existing faults. What happened is the LOW speed on both fans are crook (probably failed at different times) with the high speed ok. On studying the wiring diagram we found shorting terminals 30 & 87a with the low speed relay in place would kick the fans on when a/c is started but at high speed instead of the low speed which is what is supposed to happen and cycle on & off with the a/c compressor.Fans also kick in with a/c off and coolant temp sensor tells the BCM its getting hot but also at high speed.Maybe there is little difference in noise level from low to high speed or my hearing is sus.Probably the case. Until I source replacement fans I am running the vehicle in this configuration with the fans operating at high speed only but when they should.Can,t see any problems with this. Any comments appreciated.
