VX Calais Dome Light always on
trozzadozza
21
West Gladstone
VX Calais 5.7
G'day legends, I've run into a dome light problem with my 01 VX Calais. I bought the vehicle about 2 months ago, and the dome light never worked. Last week I decided to have a look at it. It didn't have a bulb in it, so I put one in. And the dome light doesn't turn off. No matter the position of the switch, the light is always on. The key barrel and drivers footwell light is pretty much always on as well. And possibly the boot interior light is on as well. Although the courtesy door lights do turn off when the doors are shut. If anyone can point me in the right direction to fix this, that would be much apricated.
Aus78Formula
VX R8 Clubsport
Perhaps headlight switch is worn where dome light lever is, and bulb removed as they knew of of problem. Also check that it doesn't have the separate dome light button in centre of dash like is seen on the police option cars BT1 and the later code.
lout
60
Langwarrin Victoria
go through all interior and remove all the LED bulbs
trozzadozza
21
West Gladstone
VX Calais 5.7
I'll go through and see if there are any led bulbs in the car. I'm not quite sure about the headlight switch, as it has the auto function and I don't know if it does anything with dome light
Aus78Formula
VX R8 Clubsport
I thought you could slide the dimmer lever into furthest notch would activate dome light, might be thinking of another model/switch.
RiffRaffMama
SW Vic
Twin VX II Berlinas - "Vanessa" and "Geraldine"
Sliding the dimmer switch only affects the illumination of the instrument cluster. It doesn't affect whether the interior light comes on or not.
RiffRaffMama
SW Vic
I have my lights on auto most of the time and the interior light goes on and off like normal.
RiffRaffMama
SW Vic
1. Check the door light switches. You could have one or more misaligned doors or a broken (snapped off) or faulty door switch that is not depressing when the door is closed, telling the car to put the interior light on. Door switch looks like this (cleanliness of car may vary):
(Driver's door)......................................................................................................................(Back door)
Go around and open each door one by one and try pressing the switch in yourself and see if that turns the light off.
2. Check wiring to same. Fairly obvious this one.
3. Switch on the interior light might be worn out. Borrow a mate's one and install it and see if that fixes the problem. If it does, keep your mate's one
4. Replace the relevant relay under the bonnet. It could be stuck open.
5. Less likely possibilities - BCM or ignition.
lout
60
Langwarrin Victoria
@RiffRaffMama
baby steps, op has just bought car
start with easy, then switches, then wiring, then exotic
