VX Commodore Eurovox Wiring Diagram
Discussion in 'Car Audio' started by jaygreenberg, Oct 9, 2004.
  1. jaygreenberg
    jaygreenberg Guest
    Hey All,
    I need a copy of the VX Commodore Eurovox Wiring Diagram, so that I can hook up my pioneer head unit onto the factory VX Steering Wheel controls in my S.
    I've already got the VT Wiring Diagram, however I need the one for the VX that includes the wires for the steering wheel controls.
    Thanks for any help.
    Jay
  2. Doctor Bob
    Doctor Bob Grandpa
    Mornington Peninsula
    VT V6 Exec & VN V6 Exec
    The Black/Red & Black/Yellow wires in the small six pin connector. i will try to post the diagrams tomorrow
    Cheers Rob
  3. jaygreenberg
    jaygreenberg Guest
    Rob,
    Unfortunately your post didn't make much sense to me, I've got no idea about this stuff.
    If you could post that wiring diagram, I can take that directly to the JBHiFi guy for the install.
    I'd REALLY appreciate that diagram.
    Thanks heaps for your help.
    Jay
  4. Doctor Bob
    Doctor Bob Grandpa
    Here is the bit you need
  5. VXWAGMAN
    VXWAGMAN New Member
    Wantirna, VIC
    VX Series 2 V8 Berlina Wagon A4
    Can you make sense of the colour codes for me please from the plug.
    B/W = ?
    B/Y = ?
    BR = I assume earth
    O/B = ?
    V = ?
    thanks
  6. TigerVX
    TigerVX New Member
    2000 VX Commodore
    As mentioned by Dr Bob, the wires you want are only the Black/Red and Black/Yellow.
    That is Black wire with Red Stripe
    and Black wire with Yellow Stripe.
  7. VXWAGMAN
    VXWAGMAN New Member
    Wantirna, VIC
    Ok could you tell me what these represent though please.
  8. Doctor Bob
    Doctor Bob Grandpa
    The Black/Yellow is the supply from the bcm 5vdc
    the brown is the signal
    dont mess with the others the are nothing to do with it
    Rob
  9. VXWAGMAN
    VXWAGMAN New Member
    Wantirna, VIC
    ok cheers. now i have something to work with when i try to interface the SWI-X with it. I just needed some idea what had power runnign through it so i dont blow something up.
  10. VXWAGMAN
    VXWAGMAN New Member
    Wantirna, VIC
    I'm Wondering if anybody in here has any clue on this or could help me. I see that the holden steering wheel controls have brown as the signal wire. I have a SWI-X controler which is something I purchased from the US and probably is setup for US or international car wiring. I have 4 choices with signal wire but I'm not entirely sure what to choose. I can choose either WHITE, YELLOW, ORANGE or GREEN as the wire of choice for signal. I am not game yet to just try them one at a time as they may use voltage and may damage the unit. Has anybody seen one of these units before or has any experience with them? the unit looks like this:
    I'm kind of going into uncharted teritory as I don't see many people who have sucessfully installed one of these things into a Commodore. The manual only gives colour codes that represent certain models and makes of car and won't actually say what each wire does except the red = + and black = ground. that's about it.
    Any info would be appreciated.
  11. TAILS83
    TAILS83 New Member
    Brisbane northside
    VZ SS
  12. VXWAGMAN
    VXWAGMAN New Member
    Wantirna, VIC
    thanks.. I found one on LS1.com.au with all the details on how to set this up. if anybody wants details on this let me know.
  13. muscat
    muscat New Member
    vx executive
    hey sort of new to this... need some help just installed a new head unit and i'm having two problems, the aerial doesn't go down when u put it on cd mode and the head unit is losing the memory. if somebody could tell me the colours of these wire it would b greatt thank u
  14. Tasmaniak
    S.E. Melbourne
  15. SmivlyDee
    SmivlyDee New Member
    vx
    they removed the link so if somebody could please repost it that would be awesome thanks
  16. rodallen
    rodallen New Member
    ipswich
    vx commodore executive
    I am having similar problems ,when I switch my radio of the antenna goes up, when I switch the radio on the antenna goes down.Help, someone with some wiring knowledge .It sounds to me that some wires may be crossed ,but which ones ? I have only just purchased the car .It is a vx commodore vx 2001.
    Thanks in advance Rod
