VX II Lower Contrl Arms
PeterVX2
VX2 Equipe
My VX II Equipe with 327,000 KLM on it has recently developed a loud clunk in the front driver side suspension area. At low speed, when I use the brakes, CLUNK !
It sounded and felt like it was coming from the brake calliper. I pulled it off and inspected it. The pistons moved OK and the pad looked normal.
I took it to the local Pedders Franchise for the $28 undercar inspection.
They said the clunk was coming from the badly worn lower control arm bush’s !
The offered to replace the arms and bush’s for what I thought was a very large amount of money.
My question is, are you better off just buying both full lower control arms like advertised on Ebay ?
I assume these arms may not have the better quality bush’s and steering knuckle ?
Or
Are you better off buying the Nolathane bush’s only and fitting them to the existing arms ?
I would appreciate any informed comment on this, especially if you have just been through this exercise.
Regards all !
vywgn
1967 Holden HR Premier Wagon / 2015 VFII SV6 Sedan
I would fit complete arms, just for the simple fact you're also changing the ball joint
shane_3800
35
places
vr commo
I wouldn't use ebay arms and as a mechanic I wouldn't fit them either.
You can pull the arms out and have them rebushed at any suspension shop using quality Mckay bushes and you can get new ball joints fitted too.
Heavy VT
NorthQueensland
Vt V6
I would suggest you do your z bar bushes front and rear while you are there too.
Pollushon
Boost gives me a bar....
VY SS
I'm a fan of the nolathane replacements. Besides being a smarter design than the press in shell, it's one area of the front end that won't see any extra nvh from urethane
vc commodore
Like the Leyland Brothers
VC, VH and VY
Why not? I fitted an ebay set to my nieces VY 18 months ago and they are still in and nothing wrong with them to this day.....She also does about 600k per week in the car as well....
Pollushon
VY SS
These are eBay arms that were sold to me as OEM. I'm sure they're all not bad but the risk factor would certainly increase
vc commodore
VC, VH and VY
EEK, not pretty.....Whilst my niece bought hers unknown to me until it came fitting time, hers were fine
Juice3
Australia
VX
