VY 2003 Supercharged LS1 Fuel setup
Kringe
61
Queensland
2003 VY SS
I have read a million threads and opinions and never found anything concrete by way of an answer to the purge solenoid question.
So my question now is, do I have this right or not ?
I`m running a wasp M112 Eaton S/C with rear intake,
your wise input will be greatly appreciated.
07GTS
Australia
VEGTS BUILT BLOWN E85
purge solenoid dosnt have anything to do with actual fuel, all it is is a breather for the tank into the manifold so the vapors are burnt, if u add it to the return will not end well, keep it as it is standard if ur using it
Kringe
61
Queensland
2003 VY SS
ok, but one end of the soleniod goes to the manifold and the other end goes to "what looks like a return line" on the firewall under the fuel line, is that not a fuel return line ?. I apologize for the noobness
07GTS
Australia
no worries, no its not a return line it goes to the top of the tank after the charcoal canister, under curtain conditions the ecu will open the valve to burn some vapors from the tank for emissions, your VY with LS1 is a "dead head system" so the fuel reg is in the tank module and only the single pressured line goes to the rails/injectors
Kringe
61
Queensland
2003 VY SS
Ahh, ok so I dont need an aftermarket fuel reg, i just plug off the end of the the 2nd rail, and just replace the stock purge hose1615616560221.jpeg to the firewall with a straight hose ?
07GTS
Australia
if ur connecting the purge to the firewall u need the solenoid also so its not constantly sucking vapors, if ur not using the purge then block off the engine side remove solenoid and just vent the firewall side, may need the purge DTC disabled tho if not using, yes just leave fuel rail same setup as standard will be fine, u may need a better pump depending on your power level expected
Kringe
61
Queensland
2003 VY SS
Thank you, much appreciated, I was over thinking it as I do :p,
