Sounds like the compressor clutch is failing. Buying a second hand compressor is very risky. I would never use one unless its absolutely necessary. $1000 is pretty fair price to replace a compressor.
Bit more work involved than most people realize. The tech has to vac down the system, remove parts, replace parts (usually including a new Drier and TX valve), Flush the system of contaminants, check for leaks, fill with gas, check for leaks again and make sure everything is operating at correct temperatures.
If you bolt that compressor on yourself you will have no warranty. Also it may be cheaper to buy a compressor off ebay but dont expect it to last longer than a year or two. A/c compressors are one of the things you should always try to fit a genuine one if possible and any reputable tech wont want to fit your ebay compressor cause they cant guarantee their work if they dont trust the parts they are using.
My work specializes in Automotive Airconditioning and Electrics and Im also a qualified Aircon tech
